thelonerider
Utah
Last week the rear diff blew up on the truck and im thinking ill just replace the whole rear end and go with a 3.92 instead of 3.55 is this just an easy pull out put another back in or is there more id have to do?
I have a commuter car so if im using my truck, its for truck things, im not to concerned about loss of MPG if it means i can tow a little better.
I also like to toy around off road in the truck and was going to put 35s on it once the tires need to be replaced.
HemiLonestar
MD
Two or four wheel drive?
Runaround
Silsbee
It should be just a remove and install but if it is a four wheel drive you would have to stay with the same gear or change the gear in the front differential to match.
DILLIGAF
Canada
You need to match the front. Look for a sport with 4.10s at a junk yard and get both diffs.
HemiLonestar
MD
He has a 2007....that ain't gonna happen lol. Plus he hasn't bothered to respond to whether it's 2wd or 4wd.
seanclark1503
Seaview, Washington
6.7 Turbo Diesel
Was there any indication / symptoms before the rear differential failed ? The reason I ask is I think that mine may be going bad .
