Rear end noise when turning right.
jaycommando
Andover MA
4.7ltr
Evening all,
I'm getting some rear end noise when turning right. Kind of a whine or grind. It reduces or disappears when I straighten out or turn left.
It's obvious when doing a swooping s turn.
I had the diff rebuilt in January and the front hubs were new last year.
My reading online leads me to think it's a rear axle bearing. But I'm looking for some reassurance.
What's your thoughts on the cause? Breaks aren't sticking and the truck runs and coasts fine.
2004, 4.7 4x4 with off road package. 171000 miles.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Check your left front , maybe the half shaft
That is a wild guess on my part
jws123
nj
Not enough friction modifier in the diff oil?
Travelin Ram
I’m a bit surprised the shop didn’t replace the axle bearings when they were in there. If I pull a differential apart, I’m not putting it back together with axle bearings with that many miles on them.
I think you need to just approach it as a fresh problem and diagnose all the possible causes. Considering the lousy state of manufacturing and supply, there’s every chance a new bearing put in recently is noisy.
