OnSale
5th Gen Crew
- Nov 12, 2016
- 3,218
- 1,723
- Location
- Philadelphia, Pa
- 2020
- Hemi 5.7L
It's definitely easier to just change the harness and parts. You only have an occupancy on the passenger seat to enable the passenger side air bags. The truck assumes that if it's being driven it has an adult in the drivers seat so there is no occupancy sensor on the driver's seat. The sensor is under the leather and glued to the foam. You can reach it from the back of the seat cushion. I'm not sure if you and get to it without removing a couple of hog rings but if memory serves me correctly you can. There is a possibility that your 12 has the same occupancy sensor as the 15 seats. If they are the same there is no reason to switch them as long as your harness will plug into it. The senor itself is just a flat looking piece of plastic with a pressure switch on it.
None of the plugs under the seat match, so if I’m going to swap all this stuff to make it plug n play swap, I minus wel swap the sensor so that plug matches as well.
Thank you for all your help. I threw out my back earlier today, so it’s looking like I’m going to have to wait a couple days now to pull my 2012 seats and swap out the parts. Hopefully I can do it later this week and finish by the weekend.
