How To Add Heated/Ventelated seats and Heated Wheel to Express/Tradesman
Athena
2016 RAM Laramie 2500 CCSB 4x4
I wonder why a person can't adjust the temperature settings of when the heated seats can be activated, when I can turn on the heated steering wheel when it's above 40 degrees listed on the outside ambient temp.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Been wondering that too.
I haven't seen anyone try it yet but there are some settings when connected to the Comfort Seat and Wheel module (CSWM) or "Comfort" module directly.
Use at your own risk
Forrest84
cutt n shoot, TX
I’m in the process of doing a seat/console conversion on my 2016 Ram 2500 tradesman with a Cummins. I got lucky and found a 2016 leramie locally with everything. I think I’ve mostly worked out how I’m going to power them but had a couple questions still.
My thought process is to get a quality pre wired fuse relay box and set it in the engine bay so I can go back to it in the future if I need additional circuits for other devices.
For the seats I would run power through the fire wall and T off under the dash to the passenger seat and supply power to both seats and the putt T taps on the under seat power under wires behind the seat harness’s.
(Now I would like to re pin the connectors to give it an OEM fit and finish but I’m not having a lot of luck finding pins in quantities less than 200 per box. Plus I’ve never re pined these connectors and haven’t yet found a video showing how to properly do so.
I can find ones that have 40-50 amp relays that are 4 or 5 pin(mostly 5 pin)? Not sure yet what to make of that.
Athena
Can someone please post all the spots in alfaobd that need enabled for the heated/cooled front seats to work? I just want to be sure that I haven't missed something in alfaobd that didn't get turned on/enabled.
My cooled function works on both seats, but the heat function does not even though the heated seat buttons show the heaters are turned on.
mjf6175
NJ
cummins
Bighorn: Try the below settings. I had these listed in my "cliff" notes that I made when I did this. There maybe more settings but its been over 8 years since I did this. Hope it helps. GL!.........mike
1) ECU Config 3: Front heated seats Present: Set
2) ECU Config 3: Front ventilated Seats Present: Set
3) ECU Config 4: Heated Seat Present: Set
4) Vehicle Config CSM1: Auto on driver comfort CSM: Feature 2-3 option
5) Front Ventilated Seat- Present
6) Heated seat material : Perf Leather
Athena
Thanks Mike!
Athena
Here's what my settings were.
1) ECU Config 3: Front heated seats Present: Set - It was already set
2) ECU Config 3: Front ventilated Seats Present: Set - It was already set
3) ECU Config 4: Heated Seat Present: Set - It was already set
4) Vehicle Config CSM1: Auto on driver comfort CSM: Feature 2-3 option - This was not set yet, but it is set now
) Front Ventilated Seat- Present - Already set
6) Heated seat material : Perf Leather - Already set
Thanks again Mike!
Does anyone else know if there's any more settings that need to be turned on for the heated seats to actually heat up?
jawzs2
Air Force
South Jersey
I don't recall anyone ever mentioning they had to set this one, but wouldn't hurt to check.
Programmed ECUs: Cabin Network:
RBSS Right Blind-Spot Sensor: Not set
LBSS Left Blind-Spot Sensor : Not set
BCM Interior Bus: Set
HSM Heated Seat Module: Set
Athena
I made some progress since turning this setting on last night
Both of front seat back rests are heating up, but the bottom cushions are not. I need to see which plugins under the seats are for the bottom cushion heater elements so I can ohm check them to see if they have continuity or not.
Athena
After driving it to work today, the driver's seat bottom and backrest are both heating up.
The passenger seat backrest is heating up, and I think the bottom is too, albeit the bottom isn't getting as warm as the backrest. Time for new heater elements?
Athena
I read that the heated and ventilated seats don't heat up as fast or as well as just the heated seats do.
My wife's 2010 Dodge Charger R/T AWD Hemi has heated seats, and those seats get hot fast and you'll end up turning them down to the low setting.
If we change the seat material type from perf leather to cloth in Alfaobd, will that make the heater pads heat up faster and better? I noticed in Alfaobd, that in the tests area there are 3 levels of heat that can be turned on for testing.
Is there a section in Alfaobd that we can set the heating level up to level 3 vs just the level 2 (low and high)?
RamDiver
Marlborough, Ontario Canada
2021 DS
I think we need a larger pole to determine if this is the case, not just a few subjective comments. Also, see the AlfaOBD settings below. If this setting is set to 'Ramp up', who knows how fast it will arrive at toasty cheek levels versus the steady setting?
On my '21 Warlock, when it's far below 0°F, even while wearing shorts, I don't last more than a few minutes on the high setting before I need to switch to the low setting.
I may explore this 'Ramp up' to high setting.
I have no idea, but you could experiment and provide your results here. :cool:
I'm not so sure there is another level of heat versus an intermediate level setting.
Possibly on a higher trim level, there's a 3-position switch for low, medium, and high.
I find the 2-level pretty marginal in its current state. The High setting gets too hot, too fast, and I can't use it for any more than a few minutes unless it's -40° outside.
And only then, because the Low setting can't keep up, it still feels too hot.
My '07 Tundra Limited had an analogue dial setting. Set it once, and it stays set to that level.
I will experiment with these tweaks sometime in the future.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Function: "Comfort"; Comfort, seat, steering wheel module: MY 2018+ powernet; Steering Wheel Temperature Calibrations Parameters; then select options
As I stated, there is no selection for anything older than '18.
Athena
It seems as though the heated ventilation bag elements for both of the front heated seats are not getting very warm at all, so I assume I might need new heated and ventilation bag elements. Both cooling/ventilated function work awesome in both of the front seats though.
Back rest heated and ventilation bag - # 4610124aa - from World Parts Direct - $256.29 each
Seat Cushion heated and ventilation bag - # 4610125ac - from World Parts Direct - $317.47 each
Does anybody here have a less costly option for replacing these elements with the overinflated Covid prices?
jh23j0b
NC
I also have all of the schematics if anyone wants them just PM me your email add and I will send them to you.
Hi. I'm interested in the schematics/pinout of the yellow connector under the seats. I just installed seats from a 2022 in my 2016 ram 2500 and the pinout is different. Email is [email protected]
