Regular or Premium gas with ECO?
What do you use more, Regular or Premium gas in your RAM?
  • Total voters
    21
  • Poll closed .
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
Do you use Regular or Premium gas in your RAM?
I was just wondering because I haven't tried it yet. Since we have the ECO system, I was wondering if anyone has tried to compare gas mileage between regular gas or premium? I wonder if premium gas will improve gas mileage to the point of not buying regular gas. I know a lot of cars are tuned to regular gas and buying premium if not required is a waste of money. Has anyone tried it?
LB3711
Trumbull, CT
3.6L V6
i use 89. Even though its less than $10 between low and high grade per tank depending on price per gallon. So you want really save that much putting in low grade gas
quietpeen
2021 TRX
Hellcat
i've always put in 87 and no issues
Appauldd
2012 Ram Big Horn
I've tried 87, 89, and now 83. I saw the worst mileage with 89. I think it is because in my area people are cheap so mid grade doesn't get used much.
I do notice that in MDS mode the truck seems to run a little stronger. Meaning the MDS stays on a bit longer than when I drive the same road with 87. Maybe the increased octane helps in 4cyl mode.
The jury is still out on which grade works best. However, I am with the masses. A $40K truck really shouldn't make a difference if you spend a few more bucks at the pump.
Besides....it's a Hemi.....not a hybrid.
Paul
garner
Harker Heights, TX
I always use 93 in this truck. My R/T I tried all different octanes and it felt like a dog with 87(probably computer retarding timing because of knocking) and not much of a difference between 89 and 93
Sagebrush2500
2013 2500 Big Horn
I put 93 in all my tanks. Cleaner, and more efficient gas. It is a total of 4-8 dollars more per full tank over here in texas. It's a 40grand MSRP truck why cheap out on 8 dollars? Not to mention I turn off MDS and get better, and or same gas mileage. Logged 23mpg on average with out MDS on high way trips, and better mpg in the city with out it.
I'm running something like 40 octane and not issues :) In my life before diesel, I always ran 89 and got better MPG.
Can't speak to shutting off MDS, but I noticed shutting off the ESP/traction control appears to improves my MPG.
Not sure if putting higher than recommended is a good thing to do.
The Low-Down on High Octane Gasoline
Gardenfan
Chetwynd, BC
Unless you are running high elevations, towing heavy in the heat, then 87 is just fine. Different areas have different qualities of fuel, water in the fuel, etc. Run each and track your fuel mileage driving the same each way, and you will probably find no difference at all.
Power247
High Point, NC
6.4 HEMI
I ran 87 exclusively until about 3 months ago when the local gas stations switched to ethanol mix. MPGs really suffered after that. I found that 93 does not contain ethanol, switched, and immediately my MPGs came back.
Gardenfan
Chetwynd, BC
Unfortunately I don't think we will be able to get away from ethanol mixes at all soon.
In order to get away from ethanol here, you have to buy 91, I don't think it has ethanol in it. But it is 15 cents per liter more. Doesn't sound like much, but their are 4 liters to a US Gallon, so 60 cents more per gallon. 87 is already 5.50 ish a gallon here!
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
what the books says, 89 for me.
Power247
High Point, NC
6.4 HEMI
Holy crap!!! I will not ***** about gas prices here again!
Graygoose
Oklahoma
Convert, for now.
small
yea, check prices in Europe, then we have no reason to be upset :)
09SMOKINHEMI
TEXAS
the only thing i complain about here in the Texas panhandle is that there's no 93 octane.... it's all over the place in the DFW area, but nothing here, so I can't use the 93 tune
Gardenfan
Chetwynd, BC
Filled up at costco the other day in Alberta, where they have less sales tax, and only paid 113.9 per liter. 4.53 per US gallon. They pay ALOT more income tax though, so at the end of the year, it all balances out.
But I was excited to pay that, was filling up my jerry cans, etc.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I try and use only gas with no ethanol. Here we have some places that have 89 with no ethanol and then some places only premium which is 91 here is ethanol free. I am not sure what to answer on the poll since I almost always use 89 which is neither. Can you add more choices?
