Jimmy68
- Aug 30, 2015
- 1,419
- 645
- Location
- Lethbridge Alberta Canada
- 2001
- 5.2L Magnum
HOLD UP! Are they steel or alloy? Alloy 15s won't fit an 01
Ford is 5 on 5 1/2.Fords used 5x135mm pattern to our 5x139.7mm. Also i believe they had smaller hubs
Yes they have. But the metric conversion is 4.7mm bigger on dodge. Ive personally tried to mount ford rims on a dodge and they don't fit without modification
Ford
1954 - 1995 5X5.5" (5X139.7mm)
1996 - 2004 5X134mm
(114mm is the 4.5" car pattern)
So were both right. The 95's down will fit but the 96's up won't.
They generally won't clear the dial piston calipers. A few kinds might but the very vast majority won't
