Rock Crawler Series 51
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
So I'm thinking these will be sweet on my truck. 01 Ram 1500 4x4
15x8 with 5 on 5.5 Bolt Pattern, Backspace 3.75 - Flat Black.
Should fit right?
Jimmy68
Jimmy68
5.2L Magnum
Fords used 5x135mm pattern to our 5x139.7mm. Also i believe they had smaller hubs
Ford is 5 on 5 1/2.
Ford as been that for many many years. From the 70's. Maybe the 60's. Ford and Dodge have shared that pattern and the 5 on 4 1/2 for a long long time.
I'm just not sure if the Ford center is bigger or smaller than Dodge on this application. Both of which can be fixed.
Suppose if I hear back from the owner the only real thing i need to know is back spacing.
Ya. 60's. My 66 Merc had 5 on 5 1/2.
My 67 Falcon had 5 on 4 1/2.
I remember running Dodge wheels on them at times.
dapepper9
Iowa/Nebraska Border
5.9L V8
Yes they have. But the metric conversion is 4.7mm bigger on dodge. Ive personally tried to mount ford rims on a dodge and they don't fit without modification
Jimmy68
Jimmy68
5.2L Magnum
Ford
1954 - 1995 5X5.5" (5X139.7mm)
1996 - 2004 5X134mm
(114mm is the 4.5" car pattern)
So were both right. The 95's down will fit but the 96's up won't.
dapepper9
5.9L V8
They generally won't clear the dual piston calipers. A few kinds might but the very vast majority won't
professionalish
