shallow mount subs
ramhunter9
P-Star Jeep Wrangler
what is the big deal ?? do they sound better ??
reason i ask is im thinking i need a better 12" sub . I have a kicker now and its only 200 rms .
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I have a shallow mount sub (actually sitting in my garage!)
I ran it for a while, it did a good job, but I ended up replacing it - I think the issue I really had was with the box (**** box at the time).
I have a RF P3 Shallow 12" - I'll let you have it for $75.
ramhunter9
ramhunter9
these are my specs now ... what will be a good 12 to put in ?? to match the amp
one , kicker 12
hear are the specs ..
# Kicker C12 12" Subwoofer Single 4 Ohm 150 Watts (10C12-4)
# Power Handling:
* Peak Power: 300 Watts
* RMS Power: 150 Watts
# Impedance: Single 4 Ohm
# Sensitivity: 88.3
# Frequency Response: 27-500 Hz
amp specs ...
350w rms 1 channel bridged
550 max
ramhunter9
ramhunter9
JJ send me a pic brother .. very interested
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
k, let me find some pics of it. :D
ramhunter9
ramhunter9
you have a pm BTW ...
quietpeen
2021 TRX
Hellcat
From what I've heard, they don't sound better...they are just designed to sound good in places that won't fit a regular sub
ramhunter9
ramhunter9
well i have a shallow box as i need the room in the back of the MC this will be better for me . i posted my kicker comp 12 for sale in the for sale section . it is just to big depth wise for my box .
JJ pm returned .... mark it as sold bro
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
sounds good!
dodgegirl05
littleton
thats why i got them, i wanted 12's and the reg size were too tall!! mine sound great but cant really compare never had any others in the truck lol
DisturbedGator
i can vouche for the p3 shallows, i have two tens under the back seat and they sound waaaaaayyyy better than the cvr 12s i had back there before. i think they are 300 rms
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
The P3 I have is a 400 watter.
Whats bad, I have only heard it in a ****** box. I never took the time to pop it in my box (and now I run a 10). Oh well, Dave will get it in a few days. :D
I like my CVR........but I am thinking about moving to a CVX........we'll see.
ramhunter9
ramhunter9
2 ohm load or 8 ohm load what is the difference ??
i see it can be hooked up 2 ways ? on the p3
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
This one is a 4ohm DVC (which can be wired to produce 2 ohms).
the lower the ohm, the more power. (i know thats not the "right" way to say that, but its the easiest)
ramhunter9
ramhunter9
so wire that bad boy at 2 ohms then ?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
hells yeah
DisturbedGator
you have to make sure what ohm your amp is stable at. i have two p3 shallow 10s and they are both dual voice coil, i wired them up to present a 4ohm load to my amp. what you do is wire the dual voice coils on each sub together. i can bring up a diagram if youd like. but ^is right, less ohm more power, high end amps that are stable at 1ohm are expensive but produce big power
glass3222
Central PA
RH You said you amp is rated at 350w rms 1 channel bridged, 550 max, but what impedance is that stable at? That will tell you how you want to wire your speaker.
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
shallow 12's arent even as good as regular 10's. the only time shallows are ever good is in a regular cab where space is extremely limited. the only thing a shallow sub is better than is regular speakers.
RH do not get shallow subs. you have the room to get regular ones...do it right. shallows dont put out near the range or volume regular subs do.
iralee
