starting from scratch
capsalot
I am looking at getting a few inches of lift.
Right now everything is stock except for the muffler. (New truck)
What would be the best route to take in lifting my truck from all stock parts?
Perferably the cheapest :leghump:
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
A body lift is the cheapest. But depends on what you want to do.
If you just want to fit a little bigger tire I suggest Level it out to start with.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
^What he said... also look into gears before you go with 35s with your setup.
OklaHemi
new age hemi
i cant give an honest opinion until i see pics
srt8dork
Louisville, KY
not trying to hijack but since i have an 08 as well I guess this questions is legitimate,
in reference to what KG and BigT said in combination, should i take that to mean that with just a leveling kit you can fit 35's?
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
i believe with the right backspacing on the rim you can fit 35's on with just a level but they may rub
EJM05
Somers, CT
440 Big Block
Yes you can fit 35's but you will have barely any articulation.
4X HEMI
Lancaster County, PA
They changed the 3rd gens in 06, all the ones prior to that you could put 35's on at the stock height. Don't know why they changed things
archeryguy07
Roanoke, Va
Well I'm definitley with Ken on that one, gears would be a must with a V6 if you are gonna go much bigger than stock size. Also, a leveling kit is a cheap way to add some lift, also a body lift. Either way have fun with it!
And we need PICS!!!!!!!!!!!
Joey93
