Strictly the 4x4 lowering thread...
Thats cool. I take you went to a machine shop and had them milled down? So I can actually just buy the 2wd kit then.
Yup. I actually used the spindles off my 2 wheel drive 2013 and put them on this 2014 4X4.So my spindles have been around the block a couple times now,lol.Any decent machine shop should be able to machine the spindles and the caliper bracket if you're so inclined to bring the wheels back in.
Dobaramguy84
Tonwanda, n.y
And I take it the other option would just be to add a small spacer in the back to bring the wheels out even with the fronts?
Dobaramguy84
Tonwanda, n.y
Have you noticed and driving issues with the 4wd?
BrBlack
Calgary Alberta
I too have installed a set of OEM 2wd spindles on my 4x4.
No issues with driving at all. Bolted in perfectly and have had them on about a year now.
*didn't see a 1" lower measurement on my ride height after install and am now seriously looking into going with a 2wd 2" drop spindle.
As long as you don't get to carried away with lowering the front of a 4X4,(up to a 2" drop), things are usually good with the stock CV's.With the 2" dropped spindles it rides and steers just like a stock truck,and should wheel align to factory specs.I ran a 3" spring drop on my old 13,and never again will I do a spring drop,we had to cut tie rods to get it to come close on alignment specs,and the truck had a fair bit of bump steer and wasn't real nice to drive at freeway speeds of 75+mph. I ran 6mm spacers on my rear tires when the spindles were stock width.
RAMSTIN
Detroit
New here and could use some advice on lowering the truck 2-4. Also sorry if this has already been covered in some old, dusty post.
This is my 4x2 with a 5.7 that I want to lower.
Bell Tech has a nice looking package (964HKP) but it is $1,676 and the Michigan and Ohio shops I have spoke with say $1,200-$1,400 to install. I know I am getting a performance handlng kit not just lowering it but north of $3k is a lot of money. One shop I talked to said they had contacted Bell Tech and they said they have not sold any of these kits yet. So any advice on the best way to do a 2-4 drop without any loss in ride or handling? Also any suggestions for a install shop would be great, I will not be doing this myself.
Thanks!
RAMSTIN
Detroit
A few more notes. I am leaving the stock 20 wheels, I do not pull anything and below is about the hardest it has every worked...
Mcgauphies dropped spindles are going to give you the best ride and handling for the front,as they retain the stock springs and alignment specs.Then just pick whoever's springs you like for the rear.Start searching on here,you'll find pretty well all the info you need to make an informed purchase.What somebody else considers good ride and handling might be more like a D8 Cat ride and handling to you.But the shops that are charging you 12 to 1400 to install a lowering kit,are definitely taking advantage of you. You could buy all the tools to do the job and still have a 1,000 left over to spend somewhere else,lol.
Dobaramguy84
Tonwanda, n.y
That's all im really looking for, I have no intentions on do spring in the front on top of the spindles. Are the drop spindles the same with as the stock where youll have to kill them down or does it tuck the wheels in?
The spindles move the wheels out 3/8" on either side.
mbaier
Oshkosh, Wi
Ok after reading 80 pages of this thread I think I know what I'm going to do to drop my 17' 4x4 1500. I've been driving dropped pick ups since 1989 and the ride quality has always sucked. Although this will be the only one with rear coil springs. I'm looking to do 2/4, I've had a 2" drop rear spring with airbags for the last year and have been waiting for a drop strut to come out but that hasn't seemed to materialize. So going forward I'm looking at the 2wd 2" drop spindle and adjust (trim) the 2" rear spring to get rear down to about 3"or so. I need to tow a 16' box trailer so I really can't slam it. Any suggestions? Thanks in advance. BTW great thread.
charonblk07
Calgary, Ab
F1-A forged 349ci
After running around with the 4.5/6.5 for the past few years and having a lot of angle on the front upper control arms I decided to do something about it. As I had the engine out for the swap, I decided to raise the upper control arm mounts.
I did have to notch the passenger-side mount to allow for clearance for the long tube headers. There's not much room between the primary tube and the upper mount but the header is wrapped so the heat shouldn't be an issue.
They turned out nice Kurtis.You are an artist with a grinder and flap wheel,the finish polish on them is outstanding,lol.
dracman
canada
2017 black out edition
Did you get a 4x4 2/4 kit without shocks? or are you just looking into other options than the belltech street performance shocks?
yes sir didnt get shocks.heard guys running factory stuff
Tyx7
Kentucky
Just got the Belltech 965sp for my 16 4x4. Anyone used and installed this kit? I have some questions on the front strut setup.
dracman
canada
dracman
canada
still waiting to do mine.what ya have prob with
firefox9
