Strut Bolt Replacement
jjbonk2
Wisconsin
I know there are a few threads where people found their LCA strut bolt to be seized and needing to do various tasks to get them off. Well I was installing my 5100s when I came across the infamous seized strut bolt. Stopped my install! I am going to replace my whole LCA (Likely using Mevotech) as my truck is a 2010. Was wondering if anyone had better suggestions than the $20 replacement bolt Ive been seeing. Will likely need new bolts for the LCA attachment to the frame as well
JB1
Houston, Texas
Better stick with the OEM bolts at the frame, those are also used for alignment.
Put some anti seize or marine grease on the bolts or inside the bushings.
