- Apr 28, 2012
- 23,298
- 45,051
- 2010 Hemi Reg Cab 4x4
- Hemi
I run 5/30 RL in my 15 wrangler. Runs smooth and quite.
You run redline in the wrangler and PUP in the ram, what's your thinking?
I have the the lifetime warranty on the ram, so I play their game, use inferior products and let them fix anything that breaks.
On a side note, the Ram has the 8 speed and the Pacifica has the 9 speed. My Ram shifts beautiful but the Pacifica can have some harsh shifts. I did a relearn on the 9 speed, hoping that will smooth things out.
If the 9 speed Chrylser uses is similar to the 9 speed ZF Honda/Acura use, gears 5-9 are dog clutches....MUCH harsher than friction clutches in our 8 speeds or gears 1-4 of the 9 speed.
You will feel it when coming out of or going into 5+. Plus those gear changes will be slower.
All in the name of 0.0000001 mpg....I test drove a TLX and I dont think it hit 9th gear until 85 mph.
But it doesnt bother you if it sounds like a train?
For all of us with the 6.4 the PVC valve is intergraded into the intake manifold, it NOT a serviceable item. If you have a PVC failure the entire intake manifold needs to be replaced.
Seriously??For all of us with the 6.4 the PVC valve is intergraded into the intake manifold, it NOT a serviceable item. If you have a PVC failure the entire intake manifold needs to be replaced.
Seriously??
That really sucks. I bet those intakes are a few hundred too right?Yeah, I saw a 6.4 getting it done at the dealer when I was explaining the Chrysler Dealer Manual to the Parts guy to get my 4 digit code. Sad, his intake was so full of nasty oil residue ****. The service manager(who is awesome) said to run the seafoam or some other intake cleaner ever 10k at least.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper St MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 4 Qts 5W-30 and 3 Qts 0W-40
1996 Nissan Altima 2.4 Amsoil SS 5W-30
Man I'd be Seafoaming that every oil change......
$1200??????????Guess who went and bought a bottle and seafoam Ed the **** out of his 6.4.......and about 1200$$.
I’m looking to see if they make an aftermarket one....
what happened?
awe, ok, but you don't need 1200 at this point?
I think I'd be sea foaming at least once a year then.
