- Jan 17, 2016
- 14,044
- 24,347
- 14 Sport
- 5.7
I would of changed the sensor first,not the oil or filter.That would of told you if it was the sensor .You know, I thought about your suggestion. But, if I changed the filter, and started the engine and saw no change, then I could change the oil but would have to change the filter a second time. You surely would not want me to put clean oil into a dirty filter. Then I would have to start the engine and see the results.
Then you wanted me to switch the sending unit as a third event, with fresh oil dribbling out of the sensor hole.
I just wanted to “get ‘er done”. I suspected the oil pressure sending unit all along. But, it was time for an oil and filter change anyway so I did it all at once. By changing the sensor with no oil in the engine, no oil dribbled out on to the floor for a big mess.
I can’t believe that Royal Purple oil would be the culprit, as thousands of people use it for years, including me. I seriously doubted that the RP filter was bad either, though it could have been. I did cut open the filter afterwards and found that all was good. Nothing broken and no sludge.
I also felt that if, after changing the oil, filter, and sensor all at one time that if the oil pressure was still low, it was going directly to the dealer….still under the power train warranty.
So, that’s my rationale, faulty though you might think it is.
But you're right the sensors do fail,mine went at 25,000 miles,at the time i did mine,there was a supposed upgraded sensor from the dealer.All i know is the new sensor hasn't given me any trouble in the 25,000 miles it's been in place.
