Rampant, did that guy have the calcium numbers on the racing oil? thanks
Who knows how accurate this is with it being 6 yrs old, but I guess it's a good snapshot.
Redline 30wt Race Oil synthetic (lab tested 2011)
Silicon = 23 ppm (anti-foaming agent in new oil, but in used oil, certain gasket materials and dirt can also add to this number)
Boron = 70 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge, anti-wear)
Magnesium = 4 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Calcium = 1982 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Barium = 3 ppm (detergent/dispersant, anti-deposit buildup/anti-sludge)
Zinc = 2207 ppm (anti-wear)
Phos = 2052 ppm (anti-wear)
Moly = 1235 ppm (anti-wear)
Potassium = 4 ppm (anti-freeze corrosion inhibitor)
Sodium = 20 ppm (anti-freeze corrosion inhibitor)
TBN = 5.0 (Total Base Number is an acid neutralizer to prevent corrosion. Most gasoline engine motor oils start with TBN around 8 or 9)
Viscosity (cSt at 100*C) = 9.9 (cSt range for SAE 30 is 9.3 to 12.4) And cSt (centistokes) in general terms, represents an oil’s thickness.
These ZDDP values are high enough here, that this oil really is only suited for short life dedicated racing engines, as the name implies. Using zinc/phos levels this high in other engines could be cause for concern, since excessively high levels, can “cause” engine damage rather than “prevent” it.
The very low TBN value in this Redline oil is also consistent with short term use only.
