RJL1
- Dec 6, 2014
- 453
- 538
- Location
- Jersey Shore-By the beach
- 2018
- 5.7 Hemi
Even with or inside.
That wheel/tire setup should stick out 1.5” past the fenders.I have a 2015 1500 Big Horn with no flares. According to tiresize.com the stock tires are 10.8" wide. I am about to put on a lift and 35x12.5 tires. The 17x9 wheels will have a -12 offset which will stick them out a half inch. Can anyone with the same setup post pictures? If my math is right, the new tires will stick out 1.35". The BW pocket flares are 2.6" front and 2" rear. I don't know if those flares would stick out too much and look bad. Ram1500rsm posted a pic earlier in this thread with a level but I can't tell the depth from the fender
What truck, rim width, offset, and tire size is that? It looks amazing! Unfortunately for me, with a lift that high my wife and daughter would need a ladder.
These are Lund flares, fuel wheels are 18x9 -12, km3 rubber at 37x12.50. Not exactly your same numbers but the widths are. I can get flare width if ya want.I have a 2015 1500 Big Horn with no flares. According to tiresize.com the stock tires are 10.8" wide. I am about to put on a lift and 35x12.5 tires. The 17x9 wheels will have a -12 offset which will stick them out a half inch. Can anyone with the same setup post pictures? If my math is right, the new tires will stick out 1.35". The BW pocket flares are 2.6" front and 2" rear. I don't know if those flares would stick out too much and look bad. Ram1500rsm posted a pic earlier in this thread with a level but I can't tell the depth from the fender
Front Flares are not on the truck in one pic, the different sheen is the paint protection vinyl installed to avoid damage from flare rub. (Highly recommended) but it's an example to compare with and without flare, other then the wheels being turned and the camera angle, meh.
Your set up looks AWESOME!!!!TRUCK: 2018 Ram 2500HD Laramie
LIFT: BDS 8”, 4 Link, Diesel, Dual front fox shocks and single rear fox shock, Dual Fox steering stabilizer
TIRES: Nitto Ridge Grappler 38x13.5R20. Load Range E
WHEELS: Fuel Vapor D569 20x10 -18mm offset = 4.7” Backspace.
GEARS: 4.56 gears with Detriot TruTrac
Bushwhacker max coverage fender flares
My wife has no issues getting in with the Amp Research PowerStep XL Running Boards
