Arkangel77
SO I just got a new set of OEM Rims and New Tires. I swapped the old TPMS sensors from my old rims to the new ones. I drove for about 30 min after the initial install and everything was fine after the swap. Then the Low Tire Light started blinking and after 5 min it stayed on solid. I went to the tire shop and they tested the sensors and they all tested good and gave an accurate pressure reading. NOW When I start the truck it usually blinks for a lil bit then goes solid. One time it was off, then blinked, then went solid. I am kinda lost - you guys got any Idea? Same sensors, only thing that's different is rims and tires and the sensors test as good so I am stumped? This is a 2009 Ram 1500 4.7L.
Thanks, In Advance. Cory C
