Tune or Not?
CaptainMax
Danville
Ecodiesel 3.0L
Hey Everyone,
I just got my 2023 Ram 1500 EcoDiesel, and probably like many of you, I am trying to decide whether or not I need to tune. If I were to tune, I would go with EOC Stage 1. I do not really need the added performance the tune offers nor the improvement in throttle lag, as I can get a pedal monster. My main concern is the longevity and maintenance of the motor and if the 3rd Gens are having the same problems as the 2nd and 1st Gens. This is my daily driver, and I have about a 10-mile commute each way during the weekdays; however, most weekends, I drive around 100-250 miles. I believe this is good enough to clear the soot build-up, but I am asking for opinions.
I know the tune is great, it will wake the truck up, and all that but for an additional $1500, do I really need it?
Any advice and or input is greatly appreciated.
Administrator
If your concerned about the engine, truthfully the GDE is a much more refined tuned than EOC. They do a lot more R&D to their tuned and actually do tuning for the automotive companies. People seem more concerned about turning off the EGR but it the byproducts of bad combustion that's the problem, GDE makes improvements with the combustion cycle. There's also a white paper that GDE published about the CP4 pump, they note some of the contributing factors of the pump failures and make adjustments in their tune for the pump.
JW2 Innovations
Preferred Vendor
Olive Branch, MS
2016 Ram 2500
I looked at the 3.0L and tried to figure out how to make it work with what I tow 50% of the time I use my truck - just from an expense perspective. My case ended up with 2500 6.7 which came with this handy screen on the dash already ;)
Either way though I would have ran with stock until warranty was no longer and then tuned it if I had bought new if I depended on dealer to work on my truck. I do my own work so for me after the first year if nothing was presenting itself engine/transmission wise on a new truck I personally would make that change.
In my case I bought used and would have put a tune on it if it didn't already have one included for either 3.0 or 6.7.
Again, can't speak to 3.0L, but 6.7 on mild tune is to me like comparing apples and oranges to non-tuned. I test drove both to make sure I witnessed the difference and it is obvious.
All in all it's a risk decision on a new vehicle/warranty. Your truck, your choice.
Another focus area when I was looking was the oil cooler on a 3.0L. I noticed later that there are after market options on metal housings now, not sure which years. But if it were available for a 3.0L year I owned I would do that upgrade as well. Plastic, heat, hot/cold, don't mix well over time. Especially if you do tow.
Good luck with your decision!
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Injector pressure, injector timing, blah blah blah....Somehow, somewhere, you have to add more fuel and find a way to make sure it all burns...And since the more you add the more unburnt biproduct you'll get, the more the particulate filter has to work and sometimes that means regen more often. It's a science that some of those tuner guys work out pretty well, and some of them don't. Regardless, it's science...Unlike the Pedal Commander which is pure hocus pocus. Flame away PC lovers :favorites37:
John Jensen
San Diego County
Ecodiesel
Do you like your warranty? If so, I wouldn't mess with it until the warranty is expired.
I tuned my 2016 Eco and my 2020 HO within the first few months of being delivered. I've never had a warranty issue denied. I'm aware that the warranty will not be honored if the tune caused the problem. To imply the warranty will be canceled because your tuned is false information.
JoshsRam
Lake Forest, CA
5.7L
I tuned my 2016 Eco and my 2020 HO within the first few months of being delivered. I've never had a warranty issue denied. I'm aware that the warranty will not be honored if the tune caused the problem. To say the warranty will be canceled because your tuned is false information.
Nowhere in my response did I say it would be cancelled. However, if you have any issue with the engine and they find the tune, you can kiss your warranty goodbye. I wouldn't personally risk it with the cost of a new engine but to each their own. My tolerance for financial risk is low so I'd rather tune it AFTER the warranty is no longer in force.
John Jensen
San Diego County
Ecodiesel
Agree, I changed the word "say" to imply. We all have an opinion, I do respect yours.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Apparently your local dealer isn't the large rooster vacuumer that mine is. I go to him for scheduled service and recalls. Otherwise, I buy the Rams out of state (mostly). My dealer wouldn't align the truck after I put the Thuren leveling springs on it because, "It's not gonna be right", yet they sell lifted Jeeps that are done locally by some hack. Took it down to the Chevy dealer who aligned it and it's perfect. Chevy guy told me, 'You're always welcome here".
John Jensen
San Diego County
Ecodiesel
I like the Chevy guy.
My dealer is great. My service manager supports tuning. When early tuning required the PCM sent in to be tuned I had a spare "stock" PCM and he would have his tech remove my tuned PCM replace it with the stock one, do their flashing, and return my tuned PCM into service. When I leveled the front end he gladly re-aligned it. He's the best Service Manager I've ever encountered in my 71 yers of owning vehicles
brian42
San Diego, CA
...My main concern is the longevity and maintenance of the motor...
No matter how much more "efficient" the tuning may be or any claims to not alter reliability there's a reason that RAM won't cover any engine/drivetrain repairs from aftermarket tuning.
The truck's components are engineered for their predetermined expected lifetime based on the conservative programming that it was engineered with.
No matter how good the tune is it will offer more power (more stress on components) and a different delivery curve (different stress on components) so will accelerate wear.
Your decision will be based on what you prioritize more: longevity or elevated fun factor.
I've been down both roads:
- My F-250 diesel was heavily modified, tons of fun, expensive to maintain/repair, and I spent most weekends in the garage working on it (tweaks, repairs, more modification). That was an 11 year journey.
- My RAM 1500 was mechanically stock, lots of fun, comparatively inexpensive to maintain/repair, and I spent most weekends out with the family having fun in it. That was a 4 year journey.
Now that I'm out of trucks and into a car I've had the itch to get back into the modification mode again but, after reflecting on those past 15 years (and I'm not young any more), I decided that I enjoy driving the car more than fixing it.
Just my .02
Scottly
Safety Harbor, FL
HO 6.7 Cummins
Mine blows. Here is my service manager, in a conversation about why he wouldn't align my truck....He likes to hear himself talk, so I just shut up and listened...He said, "....See that bachelor degree hanging on my wall? That means I know just enough to be dangerous and I'm telling you that those level springs are a problem, but if you wanna do something that stupid, go ahead. I won't align it". I didn't reply with my degree credentials or experience...I just smiled, walked up to the front sales area, and said to the sales manager, "You asked me why i bought the last two trucks somewhere else, well...Maybe you should ask that arrogant POS service manager you have the same question". Funny thing is, the Chevy dealer and Ram dealer are both owned by the same group. When I mentioned my bad experience while at Chevy, they just said, "You're always welcome here and we'll never treat you like that. We can't speak for that guy. Unfortunately, we can't handle your recalls or warranty work here, but please keep us in mind for any of your other needs".
John Jensen
San Diego County
Ecodiesel
Yes, it's amazing what one person can do to a dealership's reputation
JW2 Innovations
Preferred Vendor
Olive Branch, MS
2016 Ram 2500
No matter how good the tune is it will off more power (more stress on components) and a different delivery curve (different stress on components) so will accelerate wear.
Just my .02
Hey MC, Respectfully I agree with you that putting more stress on things when "heavily modifying" any vehicle can and does cause issues/damage.
But I think there's another item missing here.
Adding DEF and all the other "stuff" to diesel engines wasn't in the original plan of this engine frame either. But was thrust upon the vehicle industry as a whole (not stating belief in either side of that argument here - just a fact as no automobile manufacturer would have added this equipment on their own). And it has taken numerous updates and part improvements to even get where we are today. In each manufacturer type.
Having myself been trained and worked on big diesel engines in the Navy there are certainly countless diesels that have ran for numerous years, some not needing any major work when maintenance is done correctly and on time. Which the Navy I was in that maintenance was tracked, assigned, performed properly, and not missed. And not one of those frames had any of this exhaust "stuff" on them that we've seen in recent years being added. I've even seen old WWII submarine diesel engines that still run today, though not in service obviously.
So I do believe there are many who are looking for longevity in their expensive to buy trucks by removing these factory add on which does require some alterations in order for it to run correctly and without lights coming on, on the dash. Not to be "heavily modified" but rather to get back to tried and true that can make the distance.
And lastly, I also agree with you that going the "heavily modified" route can be a lot of fun - but certainly does cost more in both dollars and time. :)
turbogreg
3l ecodiesel
IMHO GDE is the way to go I absolutely love it their customer support is really the best. I installed it and wish I had done it sooner.
Read the GDE reviews.
