Yea,they are just stone-der and free after midnite. Cause most customers have gone home already to their wives. LolAre dollar hookers ok BEFORE midnight..
My truck calls for 39 PSI, and I run that. I have also experimented with air pressures all the way down to 34 PSI. I believe the lower pressures may absorb some of the vibration but in my mind...that's not a fix, its just a band-aid. The vibration is still there. My shocks are 4 months old. When I installed them, it made no difference at all. I was really hoping that was the problem.
Random plug from my buddies suggestion. Possibly warped the rear rotors enough to warrant a high speed shimmy? Thoughts since it seems anything is currently plausible
Sent from my P00I using Tapatalk
It's crazy all the variables at play when it comes to NVH on the highway. Add another crazy situation to the list.Just an FYI, when I bought my truck new in 2014 I had a small shake in the front that at freeway speed could be noticed. I took it back to the dealer multiple times without a fix. I lived with it for three years until I changed my brake pads and to my surprise found what looked like a rotor that had been dropped under heat (it had a dent in the rim). Long story short, the pads where getting tapped by the rotor on rotation enough to make the front wheel barely shake until freeway speed.
I'm currently dealing with something similar on my 2016. 70-80 mph is garbage. Been a constant battle for a while now with no answer.
I just had the driveshaft u joints done. They are Spicer 1350. Have a shop do them as you need a pretty good press and torch to get the plastic impregnated ones out. There's also an output shaft bushing the slip yoke rides on that may be wiped out. Tail housing doesn't come off these t cases, at least on my 2016, so check yours for slop.
Try a road force first, and check for runout in tires and wheels. If that is all good and doesn't help, look at driveshaft and t case output. Moving forward I'll keep updates as I try them.
Sent from my SM-N920V using Tapatalk
