Water in cab of 2020 Big Horn
Tom15
New york
Hey all. I’ve read about the posts regarding water getting in the cab, but don’t think I’ve seen this issue. I have water in the driver and passenger foot wells, as well as moisture/wet carpet in the rear passenger area as well. The front is worse as I was able to ring water out of the padding. Can this be from the ongoing rear light issue? Maybe there’s a leak in front as I can’t findl any way the water traveled from the back to the front. The car is parked on a slight decline from back to front. The vehicle is out of warranty by a year. Any advice on how to proceed with the dealer. ThanksIMG_0731.jpeg
18harvest
huntsville
Have you driven through any standing water? I had a camaro one time that I did that and the front floor pans where it meets the firewall didn't have enough seam sealer.that or a stopped up ac drain line.if it was the windshield I think you would hear wind noise.
Dodge 1500 4X4
Rochester, NY
If your headliner is wet, it's from the CHMSL or shark fin antenna, or roof seams the rear floor area could be the cab vents, or rear window frame cracked, or drains clogged, front drivers' side could be the A pillar body seam that requires the drivers front fender to be removed or a windshield leak, passenger side A/C evaporator drain located on bottom of firewall, if you park on an incline with the rear higher than the front the water could be pooling from the back area, front floor boards have body plugs in them if they are missing you hit water you will get water in them.
Orca
