Love my Ram but had the same issue of water behind my back seat for quite a while. Replaced the seal twice on the 3rd brake light but noticed both times that there was no sign of any moisture behind the light nor any staining on my headliner. Took my truck to the dealer and paid them $149 to tell me the back window was leaking and quoted me $600 to pull the window, reseal and re-install so I said no thanks, ordered the replacement “Bodyside Aperture Exhausters” cab vents part number 68323649AB and decided to tackle the job. Took about 90 mins with some air tools and a buddy’s help. Old vents were loose and clearly leaking. Took some finagling to get old vents out and then attached some string to new vents and passed them up between bed and cab while my buddy pulled the string from above. Space between cab and bed on passenger side was a little tight but we were able to get vents aligned and they snapped right in. While we had everything apart I blasted the light, window, and between the cab and bed with a hose for a few mins and zero leaks. Note about vents… there’s a very clear design difference between new and old vents including fewer individual flaps on new vents, a cup/channel on the bottom of inside of new vents obviously designed to channel water back out of the truck if any gets past the flaps, and a much better seal on the outside that compresses when vents are snapped into place. I strongly recommend swapping vents ASAP if you’re getting leaks or even proactively to prevent them. Original vent design is poor at best. Good luck in your water intrusion battle but vents are clearly faulty on these trucks.
