Wow that looks really clean, nice
LolIt’s amazing what a few feet and the right angles do lol. Take a couple steps and the rear wheel well bubbles start showing...
O Lord lol a nightmare. Seized bolts is why. Lower strut bolt will almost garaunteed be seized and also pitted and seized inside the bushing... once you tackle that debacle your gunna have seized upper strut bolts lol. If I had a saw to cut through the strut rod I woulda done that but didn't have a blade that fit through the coil. Ended up having to weld tacs onto the rod (see pic) to have some bite to lock some serious snap on pipe grippers to the rod so I could keep it from spinning while pounding the SH $T outta the upper strut nut with a air impact on highest setting. Beat the hell outta my hands and wrists holding onto the rod through that lol, and that disaster is all after you finally manage to break apart your lower bolt [emoji23]. It suckedWhy was it such a chore to put in the 5100's?
Lol right now I am cringing at every stop, my brakes can't get here soon enoughWell I pulled a cardinl sin.....installed slotted rotors and ceramic pads without pix........al I can say in my defense is I was hell bent to get it done and by the time it was , I full of myself and tired as **** ( I dive all night in a semi)..........I'll post a pictorial when I do th rear axle.......til then I don't have to cringe every time I see a stop sign!!
Brakes are gonna be due for me soon, too. They squeal when I inch forward and gently brush the brake pedal at a stop.Lol right now I am cringing at every stop, my brakes can't get here soon enough
Nice work bro! Looks awesome man, and of course your talking about polishing [emoji23]Well spent 10 hours tearing down my replacement motor that will be going into my black reg cab soon
I went through the entire motor and checked everything out, replaced all gaskets, replaced all sensors, new water pump, thermostat, deep cleaned the entire motor, and pretty much going through everything i can with a fine tooth comb trying to make this thing be as close to a bran new engine as it can be, and when im done it will be almost as clean as one too!
How it started
And all the progress pictures...
Pulled off the water pump that was on it and the cooling system was clean as can be, but i replaced it anyways and got rid of the pump with a plastic impeller and put on one with a metal impeller
More progress pix
You can tell this was a very cared for motor and itnreally is a low milage motor
Partially re-assembled with clean valve covers and of course i put my Instagram stickers on this motor too...
Bout as clean as she can get...
All grease and dirt has been removed, the heads are a really nice shiny aluminum, once fully assembled im gona go through and see if incant polish the valve covers and as much of the motor as possible to try and get more of that original new shine out of it...
Okay, v6 or not, that os great work, my dude.Well motor is finished, garage is clean, next step is the installation in 2 weeks...
