Whats my top towing capacity
Soaringcook
hemi v8 5.7
I have a 2016 ram 1500 quadcab hemi 5.7 with 8 speed tranny. Big horn.. Im thinking of buying a travel camper, what would be my max towing and also what do you guys consider a confortabke towing capacity for my ram.
rule18
Admin
Administrator
NY
2017 Rebel
Go here, https://www.ramtrucks.com/towing/towing-guide.html click on Look Up My Vehicle, then enter your VIN. You'll get your exact specs per your trim level. Don't listen to the TT sales people, they typically know very little about your truck, and lots about how to make a sale. :gr_grin:
jvbuttex
I-6
Always check your door sticker and the RAM link above. However, to give you an idea i had a 2015 1500, it would pull the 6000lb TT we bought. problem we had was too much tongue weight. Pulls fund stops fine, just that tongue weight was my arch nemesis.
Administrator
What a truck can tow isn't always what the driver behind the wheel who's responsible for how the trailer is set up and loaded is capable of.
You need a 4500 ram! Your 1500 is not designed to tow!
only a 4500??
more like this...
Irishthreeper
only a 4500??
more like this...
I’m sure you Cummins folks are nodding your heads in unison…yup, that camper needs a 3500 dually
marine6212
only a 4500??
more like this...
Tired of seeing new threads about towing! This subject has been beaten like a dead horse and dragged through the mud sideways!
A little reading on this forum and they could have the answer they seek in 5 minutes..
Rlaf75
East Hartford CT
You dont actually have to read the threads you dont like
Fake-Account27
Maryland
Diesel
You will run out of payload long before you run out of towing capacity. You can get your exact payload on the door jam. I am going to assume 1700 for these calculations.
1700 lbs -(total weight of all passengers) - (weight of gear in your bed) = available payload.
Subtract 100 or 200 lbs from your available payload as a safety buffer then divide by 0.12 (the average tongue weight on most trailers). This gives you your max towing capacity of your fully loaded trailer.
For my truck (Ram 2500 Cummins)
2200 lbs payload - 800 lbs (2 adults, 3 kids, 2 dogs) - 200 lbs of crap in the bed - 200lbs buffer = 1000 lbs.
1000 lbs / 0.12 = 8300 lbs.
My trailer weighs about 7500 lbs loaded and it is quite normal for my total payload with tongue weight to be around 2000 lbs.
huntergreen
2000 lbs tongue weight ?
2003F350
6.7 CTD
While he explicitly stated what his tongue weight was, it IS possible to find Travel Trailers with tongue weights getting close to 2k. In his case, that much tongue weight would basically mean he'd be over his payload if he put more than himself in the truck.
All of that said, it's really the GAWR that you need to stay under, which you can't accurately check without a scale. Problem is I can't think of a SINGLE RV dealer that has their own scale so they can set your system up properly, most of them just eyeball it with a tape measure - which is why I had significant sway after they 'set up' my 35' travel trailer behind my PW. Couldn't run more than 62 mph or it was all over the place. A couple adjustments later and I can safely run 65 mph and it's rock solid, with just a standard WDH and a standard friction sway bar.
huntergreen
Thanks for this explanation.
Gero
Ontario
I'd keep it under 24ft and under 6000lbs loaded if you want a comfortable tow.
You can stretch it to 28ft and 7000lbs but the experience won't be as good.
JerryETX
Elgin, TX
Hemi 6.4- 3:73- 6 Speed
As stated with a half ton it's more about payload and sway than tow rating. An RV dealer will tell you since your truck can tow 11K lbs that you can buy a TT that is 10-11k lbs and that's just crap! What Fake-Account 27 said about running out of payload is true most of the time.
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
1700# is quite high for what the OP said he had. Ha may have as little as the 1309# payload that I have...
Fake-Account27
Maryland
Diesel
Yeah I have actually never owned a 1500 series truck so I was guessing, but 1300 is only 150 lbs better then my minivan.
Administrator
This has similarities to male cow feces.
It comes down to how the truck, trailer and load is set up. I have had a 32' behind mine that's over 7K lbs and it tows like an arrow. One hand on the steering wheel and cruise set. Unless there's strong winds or a storm, if the trailer doesn't tow as smooth as driving just the truck there's something wrong.
mtwofeathers
Kingman Arizona
Diesel 5.9
Not a matter of what
Its not a matter of what you tow, but how you would stop one. There are 6 variations on that truck. The 1500 isn't really designed for towing in the first place.
Other than checking the owner's manual, you can do a little bit of basic math to figure out your RAM towing capacity. Find the vehicle's curb weight, add it to the payload weight (if you're carrying anything), and subtract that from the vehicle's GCWR (or Gross Combined Weight Rating) to get your max towing capacity. But like I said passenger's extra stuff in the bed, even a hitch if your truck doesn't have one can add weight to the calculations. And change towing capacities. The 1500 limitations are mostly axle, brakes. A tuner wouldn't hurt, extra capacity for the rear, can be bags, and anything to stiffen it up. Tongue weight can be solved in many different ways. But added weight to the truck.
