Wire issues
Ramdodge
5.7l hemi
Hey I'm having A huge problem with my lights, I have only a high beam on driver side and only a low beam on pass. Both front signals won't work and only pass. Side brake and turn signal works, I've replaced everything from bulbs to taillight boards checked all fuses and just replaced the front control module on the side of the tipm fuse block, I'm out of ideas, is it the fuse block and if so is there a cheaper route to fixe other than a 300 dallar fuse block?
