JBA Long Tube Headers!
BlackRamHemi
Edmonton Alberta Canada
copy/paste from another board:
This is a NEW JBA part that is in stock and ready to ship. You guys wanted a stainless header that did not break the bank so here it is.:rck:
There is no mistaking that the 5.7L Hemi has first class power in the truck and SUV market. JBA's new Stainless Steel 1 7/8” Long Tube Headers for this awesome power plant have been engineered to deliver more of that power throughout the RPM range where it can be put to good use. Any truck owner can tell you that low-end torque comes in handy when hauling or cruising. Mid-range power when charging a hill or passing on the freeway rates high on the wish list too. JBA addressed both of these areas and added an extra 30+ hp to the peak power as well. How does an extra 24 lb-ft. @ 2100 RPM sound? You have plenty of options to suit your needs as well - "works" finish stainless steel or high heat rated ceramic coated.
Features
• 3/8" thick laser-cut flanges
• Firecone® technology collector
• One piece CNC Mandrel-bent stainless steel 1-7/8" primary tubes
• JBA sealing rings on head flange
• Premium quality hardware included
• 02 Extensions Included in kit
• Optional ceramic coating (thermal barrier)
• 360 degree Tig & Mig welds
• Oversized exhaust ports
2009-2014 Dodge Ram 1500/2500/3500 5.7L Hemi 2&4WD
6961S
Jobber $599.99
http://images.pertronix.com/Exhaust Products/JBA Exhaust/6961S.jpg
6961SJS
Jobber $737.99
http://images.pertronix.com/Exhaust Products/JBA Exhaust/6961SJS.jpg
6961SJT
Jobber $737.99
http://images.pertronix.com/Exhaust Products/JBA Exhaust/6961SJT.jpg
This header kit come with reducers so you can hook them up to the factory Y-pipe or we will have a couple different options on Y-Pipes in the near future. Parts are already in stock at Moe's Performance or your favorite retailer.
Matt, they claim you have them but I don't see them on the Moe'sPerformance website yet.
Can you get me a quote on a set (6961SJS) Silver Ceramic Coated) shipped to Edmonton?
DavidRam
SoCal - Redondo Beach
2012 RCSB
Ok, I loved my JBA shorties until I saw these... :( Does anyone know if they are CARB certified or if they will pass California smog inspection???
Arctic-Rodz
RGV, TX
6.7L Cummins
those look pretty freakin good..... hmmm
TylerB
FL
Doubtful, they will fail a visual inspection because they move the cats out of there factory location.
They look exact copies of the ARH longtubes.... minus the ball/socket of the ARH.
DavidRam
2012 RCSB
Yep, I think you are right on. Just checked JBA site and they have a big notice saying that they DO NOT pass in Cali. :(
One more reason to add to my long list of why I need to move out of this state...
Arctic-Rodz
RGV, TX
6.7L Cummins
so they completely delete the OEM cats?
I haven't bothered to look at the original manifolds
BlackRamHemi
BlackRamHemi
No Cats
if you need them you would have to add them on your own,
in addition to a new cross-pipe and Y pipe like ARH's LT's
Here's my stock cats after JBA Shorties, with a Maggy Y pipe
My JBA Shorties compared to Stock 4G cast iron Log manifolds
I no longer need Cat's, the rear o2's are tuned out since adding a Supercharger kit,
and the stock cats are the biggest restriction in my setup now.
Jerseymike
Uggghhhh!! Those are nice. Anybody want to buy a set of 6 month old BBK ceramic coated shorties???
Arctic-Rodz
RGV, TX
6.7L Cummins
nice, cant believe how cramped those OEM manifolds are. If I get headers I want to run it with cats, tired of having to worry about the yearly state inspection.
BlkRamRt
SoCal
HEMI 5.7
lmao me too.... what part of socal?
EdmontonSS
Edmonton, AB, Canada
Oooooh I like the looks of these. First Edmonton is getting a Carl's Jr, now JBA makes long tubes. Ill have to get jobber price and see if I can get them through work here, test them out. If those bolt up directly to the OEM flange on the midpipes, then Ill be a happy camper!
Good find!
BlackRamHemi
BlackRamHemi
They will not direct bolt to anything stock except at the heads.
Only Shorties are a direct bolt in replacement to stock manifolds
(see pictures I posted on page 1)
Long tubes move the collector about a foot and a half further down stream (eliminating the stock cats and the ball flange)
Anyone installing these will need new custom mid pipe bent and welded in.
(and cats if they don't have the rear o2's tuned out)
and a new Y pipe.....or new pipe to a dual-in dual-out muffler.
Kind of leaning to a new 18" Magnaflow 2 in 2 out muffler with a built in x myself (currently have 22" Maggy catback)
DavidRam
2012 RCSB
FYI, for the Cali guys - Jba shorties ARE carb certified, but that is about it.
BBK shorties will NOT pass smog (despite the fact that they are made in California).
ramathorn14
Alberta
I've been thinking of running two separate mufflers, what's your reasoning behind this dual in dual out setup?
BlackRamHemi
BlackRamHemi
The two sides need to be linked with an X or and H to take advantage of exhaust scavenging (google it :) )
...in a nut shell, The exhaust pulses from one side creates a vacuum effect pulling alternating pulses from the other bank for better overall flow.
The muffler I'm looking at has a built in X pipe, similar to this:
...plus its cheaper than buying two mufflers
bouf0010
I wonder if it still has the same scavenging properties as a seperate x pipe - it appears to be perforated, would that affect it?
Sent from my SGH-I317M using Tapatalk
electricalservice
