2015 Alpine sucks.. changed everything but the HU
S
Spanka
Cummins
Well pac is installed, I feel like I owe someone money for pointing this little gem out to me.. it is amazing and solved my issues completely!!! Full signal to 20hz my system pounds now and eats these lows like a beast! Tuned to 25 may try to go a tad lower but what a difference!! Thank you guys SOOOO much!!
S
Spanka
Cummins
I ran the wire down to the area in front of the cup holders its a large open area and holds a lot of equipment. I have the viper brain, smartstart module, DBall module all of my sensors, tilt sensor, proximity sensor, shock sensor, glass break sensor and now the PAC amppro!!
All of my alarm controllers and sensors are in this area as well as you can see in the picture.
Witch
Hemi 5.7 liter
wow man that is so awesome, just way above my pay grade ?
TomT
SoCal/OC
It seems much cheaper after you spend days and weeks fighting to get a clean signal out of the Alpine system. LOL
ivey_usmc
Austin ,TX
Hey Spanka, what will you do with your old alpine speakers?
salazarn54
Hey bud I believe I was the one that recommended the pac on your thread. I’m curious did you just run your sub thru the pac? Or did you amplify your high and run then thru the pac also?
Glad the pac worked out for you.
Jwithing
STL
How much for the turtles?
S
Spanka
Cummins
Hey guys, first off... My turtles are embarrassed, and are not for sale. Haha.
I'm just using the pac for my subs, I may try to amp my door speakers again now that I have this pac unit though because this pac unit does not have the gain hiss like the lc7i did.
But I have Hertz hi energy in the dash and doors and to be honest the factory amp pushes these really good! Besides id lose my surround sound if I amp them again.
And I keep everything I take off my truck just in case I decide to sell it I can go back to stock.
S
Spanka
Cummins
Also, my remote from the pac turns off my amp as designed. I know someone had to send theirs back because it didn't work.
TomT
SoCal/OC
I just upgraded from a full set of Hi Energy (3 ways in front and coax in the rear doors) and they definitely like being pushed by a quality amp. I was running a Zapco 150.6 on mine and they took it like a champ. I used a Focal passive crossover that allowed me to biamp the front set.
S
Spanka
Cummins
You're also running a high end DSP for delays and such so you can still set a nice sound stage. I don't have that, so if I were to re amp the doors and dash I would really need to get a DSP to set it all up correctly. I just don't want that hassle, possibly in the future if I get really bored I will.
I get bored easy.. so its a really good possibility that I will at some point get it done. I will definitely be talking to you again if I go that route haha.
