Horscotta
2013 5.7 Hemi Tradesman.
My issue started when driving down the road, all of my dashboard lights went crazy. I turned my truck off and couldn’t restart it. I disconnected the battery for a minute and everything was back to normal. The next day I used my remote start and it was doing the same thing. Dashboard lights going crazy and my truck wouldn’t start. Later on in the day, it had a minor rough start then died about 3 seconds later. Dashboard still flickering and going crazy. I had these codes when I checked 2 days ago:
U 110C lost fuel level
U 1110 lost wheel speed message
U 1120 lost wheel distance message
U 1403 implausible fuel level
U 110E lost ambient temperature
U 0400 faulty ECM
Now the only code I get is:
P2127 throttle pedal position sensor.
And the check engine light is on and the red **)lightning bolt(**
It starts completely fine now but consistently that code and check engine light and lightning bolt.
I have a new battery (less than 6 months old).
Any suggestions? Thank you!
U 0400 faulty ECM
