All shifter lights on with no shifting out of gear
Noob
Tennessee
Hi, I am new to this forum and need help with my 09 ram 1500. A few days ago driving home all the shifter lights lit up green except reverse was in red and multiple lights came on( transmission oil temp, battery, cel, esp, service 4wd, traction control, the lightning bolt in parenthesis, and abs). When we got home and turned the truck off and tried to start it, shifter lights still lit up but truck was not starting. After waiting for about 30 minutes, the truck started right up but after letting it idle for a few minutes all the lights returned. Went and got a cheap scanner and found codes p3400, p1128, p1129, u110c, u1110, u1120, u0141, p0157, p0158, u1403, u110e. Thanks Noob
Ken226
Washington State
It sounds like your PCM lost communications with pretty much everything.
Mine did something like this once when a loose boot lace tangled in the big computer connector up under driver side kick panel, by the emergency brake pedal, and disconnected that big cable from the computer.
Maybe a computer cable or ground cable is loose or got disconnected somewhere near the kick panel or under the hood.
Edit to add: I looked up those codes, and u1403 seems to be related to that big connector above the e-brake pedal. Check that connector.
Ken226
Washington State
So, did you ever get it fixed?
