MitchTheFridge
Ran my 09 5.7 liter ram 1500 out of fuel today put probably close to 30 liters back in but now it wont start. I've ran it out of gas before and it fired right up as soon as I put gas in? Any ideas?
YesCan you hear the fuel pump engage?
There is a fuel pump relay located under the fuse panel by the battery, this unit is called the TIPM, total integrated power module, you need to rent or purchase a fuel pressure gauge and connect it to the fuel rail by the fuel injectors, do what 62Blazer said and see if you have pressure about 30-40 psi, you may have smoked the relay or fuel pump, there is a bypass cable you can install in the TIPM to bypass the relay these guys make that cable, contact them and they can help you.I would turn the key on (but not crank it) for about 15 seconds, then turn it back off and then on again for 15 seconds, and repeat that maybe 4-5 times to let the pump run and try to get fuel to the engine, then try to start it. If that doesn't work and the engine still won't start I would suspect the fuel pump died or it might have sucked up any debris and dirt that was sitting at the bottom of the tank and plugged something up.
probably ruined the fuel pump. If you have run out more than a couple of times it is dead. You may 'hear' it running but chances are it is not pumping anything, that is why you NEVER let yourself run out of fuel. Why do you think they put warning lights and alarms on most modern vehicles? Time to have a new pump installed and do NOT run out of fuel any more. Good luck, cheers.Ran my 09 5.7 liter ram 1500 out of fuel today put probably close to 30 liters back in but now it wont start. I've ran it out of gas before and it fired right up as soon as I put gas in? Any ideas?
