Alert on navigations?
21SilverRam
Maryland
Hello,
Is there a way to get an audible tone when using the Ram navigation if the navigation found a quicker way to where your heading? I swear my 2017 would give an audible alert! On my 2022 I just get a message that states it found a quicker route. Do you want to review? If I happen not to catch it on the screen then I’m out of luck! I’ve searched through all the settings I can’t find it if it’s there. I have the 8.4 screen in my truck.
Thanks in advance,
Matt
Loudram
Just a sinner saved by grace
South Jersey
Are you sure it wasn't Android Auto and Google Maps? That gives you an audible alert if it finds a quicker route.
I've never tried the installed Nav, not when I have AA and Maps. Is there anything that the installed Nav does that Maps doesn't do?
KoboldTaco
Los Angeles
Cummins 6.7L
My 2022 with the 12” makes a three-ding chime while lowering the music volume. I hate the re-routing in LA. It’s NOT faster and often local streets with endless stop lightS so I’ve turned it off.
21SilverRam
21SilverRam
Maryland
I’m sure I was using the built in navigation. I wasn’t using car play when I would get an audible alert.
