Wind buffeting ?
2014 Ram
Sunny South Florida
2022 Ram 1500 Bighorn 2wd
Hey guys, I never owned a 4 door truck or car before this new 2022 Ram 1500 I purchased last week. Got the front windows tinted 2 days ago, so i cant roll them down, but decided to roll the back windows down since it's a nice cool day here in south florida. That's when i hear a rather annoying vibrating sound. Pull over and tires look fine, come home and lugs are tight and nothing loose under the truck. go to dealership but they are too busy and almost closing. I search google and they call it "wind buffeting" (Helmholtz Resonance) ?
I guess its normal for it to sound like a helicopter vibrating because of the inside and outside pressures against each other huh ? absolutely crazy, cant enjoy riding with the windows down i guess, which isn't that much of a problem down here since 99% of the time its too hot to... Just wanting to confirm it happens to you guys with 4 doors also ?
Thank you so much for any input...
turkeybird56
Central Texas
Yeah, U have to balance off the openings or U get rocked. But remember, the cabs are not air tight, there are rear vents behind the rear seats also, so U get that "flow".
Sometimes I drop both rear windows and open the sliding rear window to equalize, but in the summer here, mostly windows definitely not open.
2014 Ram
2014 Ram
Sunny South Florida
Wow thanks so much guys, I really was worried, but figured it couldn't he too serious since it went away once I closed the windows.. you would think the service department at the Dodge dealership would be able to tell you something about this, but they didn't. Oh well thanks again I'm sure I'll come up with more questions
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I also get the helicopter sound in my car and RAM .
As mentioned crack a window or 2 till you find the combo that works for you !
Congratulations on your new RAM
The Challengers are bad for wind buffeting to,way worse then my regular cab truck is.The wifes Challenger will buffet so bad,the shoulder strap on the seat belts will beat on you,lol
2014 Ram,
if you have the owners manual, it describes the WAP WAP WAP of the helicopter blades
sometimes when the wind is striking the truck at just the right angle, my Ear Drums slam open & shut, just like being in a building with a Band that is playing the music too loud & the acoustics are terrible
turkeybird56
Central Texas
2014 Ram,
WAP< WAP< WAP, me thinks he not driving a HUEY LMAO..... :33::angels25:
HuskerRam
Tucson, AZ
3.0 Ecodiesel
Happens to me all the time. I think the owner's manual addresses it:
Wind Buffeting
Wind buffeting can be described as the perception of pressure on the ears or a helicopter-type sound in the ears. Your vehicle may exhibit wind buffeting with the windows down, or the sunroof (if equipped) in certain open or partially open positions. This is a normal occurrence and can be minimized. If the buffeting occurs with the rear windows open, open the front and rear windows together to minimize the buffeting. If the buffeting occurs with the sunroof open, adjust the sunroof opening to minimize the buffeting or open any window.
Lee955i
Lakeland, Fl.
Yep, every day when I hit the highway on the way home, front windows down and loud buffeting. I just open the rear slider so the air can flow...
turkeybird56
Central Texas
I miss the old vent windows and the floor vents. Never had that sound using those.
(But I don't miss my feet getting wet in the rain LOL)
yeah, I used to keep the floor vents open for airflow and cooling back in the day. Of course, back then we did not have AC a lot, and the side window vents helped to clear the front windshield also.
ctwalton15
Kansas
Yea definitely if you have the rear sliding glass, makes a hell of a difference. Especially if you open your front windows going down the highway and don't want the wind to rip off your hat or want the wind drying out your contacts (in my instance) I open the rear glass and it perfect. Good ventilation and you aren't getting violated by the wind.
Hardracer
2010 1500 laramie 4x4 crew cab
Rear slider definitely helps but you cant eliminate all of it
Dusty
Rochester, New York
The unfortunate consequence of increasingly aerodynamic designs.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 83407 miles
