headshot001
Recently aquired a 2013 Ram Slt with 71000 miles. Always ran a little warm (125 degrees) but with warmer weather started overheating 130 plus degrees and over 140 when towing a trailer. Repaced water pump, thermostat, belt, took off radiator and had radiator shop clean and test. Still over heats when on the interstate amd
Towing. It idles forever without getting above 203 degrees. Drives around town fine unless it’s under a load like pulling a long hill. Coolant gurgles in tank at 230 degrees. New coolant premixed. System burped till no more air bubbles from radiator then put the cap on and did the same at the neck on the engine where you burp them.
I am at a loss of the continued overheating issue.
Suggestions? TIA
Suggestions? TIA
