2wd lift
  1. 14Fiveseven
    Need Emergency Help for 2wd lift
    So I decided to pick up a cross member for a 4wd 4thgen ram 1500. I wanted to put this on my ram 1500 2wd. I already had a maxtrac 7 inch lift on my truck so I figured it would help lower the lower control arms so they wouldn’t sit as high on the part where they mount on the truck. Unfortunately...
  2. H
    2WD Bilstein 5100 Help
    I have a 2WD 5.7 1500 and want to level the truck without using spacers, and was pointed in the direction of the 5100 Series shocks. My buddy says the shocks will not level the truck, but after a phone call with tech support at 4 Wheel Parts they say it will. Anyone have any experience with them...
  3. Famous06
    Maxtrac
    I have a 2009 ram 1500 4.7L 2wd. I am interested in a set of Maxtrac coils 2.5 (752425-8). However when I checked the Part number of came up for the 5.7L hemi and the ones for my truck have a part number of 752120-8. The person selling the coils said they work on the 4.7L is this true?
  4. Aaron83d-150
    D-150 questions Tires Control, arm, lift
    I recently bought a 83 d-150 with a broken passenger upper control arm. I got some solid arms and I found some tires there 31-10.5-r15 do I need a lift to run these tires? Also what’s the best way to change a control arm?
  5. Moparmayhem
    3 inch rough country lift
    Hi my Dodge friends, I'm new to this as of 3-29-19. I have some questions about installing rc 3" lift. First off I installed 1.5" coil spacer a few years ago and it seems like i have had front end problems since so i bought the new kit from rc including new coils and new shocks. Do i need to...
  6. H
    275/65r20 on RC 3” coil spring lift?
    Hey guys, new to the forum here. I recently bought an 04 Dodge Ram 1500 SLT 2wd. Came with nearly bald 33” street tires on the stock chrome rims, (Which I hate). I found a guy selling a set of Fuel Battle axes 20x10 with 275/65r20 Nitto G2 At’s (34”) for $1,000. I’m hoping to buy them in the...
  7. F
    Suspension between generations
    Out of curiosity, how much did the front suspension change on the 2wd, between the generations?
  8. Michael Ramos
    BIGGER LIFT
    I have my 2009 Ram 1500 2wd with a 7 inch max trac suspension lift. I want a bigger lift like 10 or 12 inches. Any suggestions?
  9. F
    2wd 2018 ram 4 inch rough country
    Okay, so I decided against the 6 inch rough country considering it's just a 4 inch lift with the 2 inch leveling springs, I already had 3 inch leveling spacers so I left them in and added the RC 4 inch, giving me, what I imagine being similar results to rough countrys 6 inch, plus 1 inch , I...
  10. ThatDavidGuy
    Maxtrac 7" vs. Rough Country 6" Suspension Lift (2wd)
    Hello all, I have a 2012 RAM 1500 5.7 Hemi 2wd and want to install a suspension lift on it. I am trying to decide on the Maxtrac 7” lift or the Rough Country 6” lift. I’m sure a lot of you here have great reviews on Maxtrac but does anyone have the Rough Country lift? I will provide the links...
Bob Templeman
