5.9 cummins
  1. C
    Radiator coolant level
    Is the radiator in a 3rd gen 5.9 supposed to be filled to the brim when the engine is cold? the expansion tank is full and I just bled all the air out of the system using a coolant funnel kit. Took it for drive then checked the radiator after it cooled down it was about 1 to 2 inches below the...
  2. D
    1995 dodge ram 2500 5.9 diesel 12 valve
    Hello everyone im new to this group and kinda new to diesel i know the parts and the basic stuff thats about it and have the manual for the truck, ive recently purchased a project 12 valve 2500 it runs and gets me from A to B but it has its problems. the problem im trying to fix right now as im...
  3. B
    Is a module required for remote start?
    I've found tons of threads on turning on remote start with AlfaOBD, but non of them mentioned needing a module or controller for it to work, they just mention needing to wire the hood latch Are there any other needed parts, or do you just have to turn it on and get a key fob with the remote...
  4. B
    Overhead Computer less accurate when not reset?
    So I know these things aren't the most accurate in general, but I read somewhere that when you don't reset the trip ODO each time you fill it becomes less accurate. Do you agree with this statement? If so why does not resetting it affect it like that? Mine seems to be reading 3/4MPG high...
  5. 0
    Air dog not priming
    Replaced filters on air dog today. I didn’t prefill the filters with diesel. I started the truck. It ran for 20 seconds and shut off. I can’t get the filters to fill by cycling the key. Any help appreciated!
  6. dehdlee Duo
    4WD bad at turning
    Hey all Wanted to get some input on a 4wd issue I have with my truck, I might need to take it to a shop to see if this is an issue but would like to get some answers first. When in 4wd High or low, not worried about low since it is meant for crawling, the truck has no truning radius at all, if...
  7. dehdlee Duo
    I am new here
    Hey all I decided to get envolved into this forum since I am new to the full size truck and diesel thing. I would like to introduce myself. I love my truck its a 99 ram 2500 diesel LB with a nv4500 5speed. Will keep this truck for a long time if not forever. I like going camping, offroading...
  8. N
    48re build
    Hey guys, so I just bought an '05 ram 2500 5.9 with a stock 48re. I'm putting a new lift pump and gauges on her soon and after that I'm looking to build my transmission considering the reputation they get. My question is what should I get done to it to bulletproof it and make it reliable? I'm...
  9. B
    07 Manual Swap
    Hey guys, I have a 2007 Ram 2500 with the 5.9 Cummins and I wanna put a manual trany in it. Does anyone know about how much it'd cost to do this? (I'm looking for both the transmission price itself and the labor to have it done, as I may end up doing it myself.) Thanks
  10. C
    Electrical Issue with instrument cluster and tuner
    So heres the deal, I have an 03 ram 3500 with the 5.9. Recently, I started having an issue with the instrument cluster resetting itself. I have been able to troubleshoot and narrow it down a bit, First, it only does it when it is cold. Once the truck runs for a minute, it does not do it anymore...
  11. Grandpa Sleeper
    Transmission heat sensor problems
    Hey guys I've got a question about my edge juice with attitude on the ole 2nd gen grandpa truck. I go into the menu and there are two different transmission temp readings, TFT (trans fluid temp) and JTFT (juice trans fluid temp) the JTFT generally reads about 30 degrees cooler than the TFT which...
Carbary
