I'm thinking about which lift kit to get for my 4WD truck and I cant seem to find any bigger than 6". I found a Zone 6" (Sister company to BDS) that you can get with a 5" coil in the back to retain factory rake. I was thinking I could pair that with Bilstein 5100 or 6112 in the front set at...
Hi Everyone,
I just installed a 6” Zone lift in my ‘13 1500 Quad Cab. I did the install myself and everything went smoothly and each component is torqued to spec (just double checked earlier today. However, I have 2 questions pertaining to the truck post-lift kit.
Kit Specs:
Zone 6” Kit
Fox...
hey guys i got 2008 1500 i currently have a 6 inch rough country lift with 37 inch tires but i'm looking into getting a long travel kit but the aftermarket support sucks for rams and anything i can find is for a fourth gen i know there are a lot of similarities in the front end components but i...
Hey everyone. Been doing research for a while and just had a "small" thought. I decided that eventually I'm going to try and re gear over the course of this summer. I've found out that in the models above 2011 it is that the largest gear you can fit in the front differential is 4.56. I've been...
