alfa obd led enable
  1. T
    Morimoto XB LED Issues
    I recently replaced my Quad Halogen headlamps & taillights on my 2017 RAM Big Horn with new Morimoto XB LED housings and consistently receive a High Beam Headlight Out message. The problem occurs a few minutes after driving when the lights are turned off. Prior to the error being thrown, low &...
  2. T
    2015 Ram Sport LED and Alfa Settings
    Replaced my low beam halogens with some Sealight LED's. They work for a while then blink a couple of times then go out. The dash then says that I have a headlight out. I have changed the settings using AlfaODB for LED Low Beam Lamps Present to yes. This change did not have any affect. Is...
  3. G
    2009-2012 AlfaODB
    Hi I have a 2012 RAM 1500 and was looking to buy the things to use AlfaODB to change some parameters on my BCM but I haven’t found anybody that has done it on a 09-12 I only see people with 13+ using it. Is 2012 compatible or am I just going to waste my money? Thanks
  4. rubes7202
    Right Rear Turn Signal Light Out
    2015 RAM 1500 Sport. Anyone have an idea of what could be causing this? Only comes on at engine start, then goes away. I turn on blinker and everything looks fine from all corners. I have the stock LED tail lights. I am stumped. Sent from my SM-G988U using Tapatalk
