2009-2012 AlfaODB
GunsNGuitars
Liberty center Ohio
Hi I have a 2012 RAM 1500 and was looking to buy the things to use AlfaODB to change some parameters on my BCM but I haven’t found anybody that has done it on a 09-12 I only see people with 13+ using it. Is 2012 compatible or am I just going to waste my money?
Thanks
smoothee
St. John's, NL
While you can't do as much, there's still plenty you can. What exactly are you wanting to do?
G
GunsNGuitars
Liberty center Ohio
I would like to switch my drl off and be able to program keys
smoothee
St. John's, NL
Drls no problem and key programming shouldn't be either, I think you need to get your 4 digit PIN from the dealer or from another app in order to program the keys but don't quote me on that. On my '11 I've changed my drls, enabled fogs to stay on with highs, and have used it plenty for troubleshooting so well worth the price imo
G
GunsNGuitars
Liberty center Ohio
Okay thanks, that makes me feel better about getting it then!
metalchewy
Las Vegas
2010 TRX4
4.7L
.... I think you need to get your 4 digit PIN from the dealer or from another app in order to program the keys
Alfaobd for android pulled my pin on my 2010 as well, without having to use pin puller, or talk to a dealer.
Its At the bottom of the radio frequency hub settings.
calidavidg
New Mexico
What about using Alfaobd to do a milage correction if I get a different evic. I have the basic cluster on my 2011. I found a nicer cluster off a 2012 but mileage is different....
da_garr99
British Columbia
Hey sorry I know it's a old thread sorry, I bought some LED oem factory tail lights and was wondering if I can change it in alfaobd to stop the hyperflashing and rear turn signal message. 2009 ram 1500
