tomof
Austin, Texas
I recently replaced my Quad Halogen headlamps & taillights on my 2017 RAM Big Horn with new Morimoto XB LED housings and consistently receive a High Beam Headlight Out message. The problem occurs a few minutes after driving when the lights are turned off. Prior to the error being thrown, low & high beams work as expected. Once the error occurs, the high beams are disabled until the truck is turned off.
After reading through the forums, I purchased AlfaOBD and set all the entries for exterior lighting to YES for LED lights. I've also changed the voltage of the low & high beams from 14.7 to 12.0v.
Reaching out to see if there are any other possible solutions from anyone who has installed the XB's from Morimoto.
