coil packs
  1. M
    2020 5.7 etorque coil boot
    Coming up on 90000 miles and getting ngk plugs but would like to replace coil pack boots also. Anybody know a part # as all online show up to 2016.
  2. J
    Coil pack wire removal 2019 Ram 2500
    What is the trick to disconnect coil pack wiring on 2019 Ram 2500?
  3. D
    04 RAM 5.7 REBUILD
    Hi everyone! My name is Devin and I have a 2004 ram 5.7. While I was riding down the road last October my main bearings went out and the crank seized on me. Completely shredded two piston heads, rods, everything, (got pictures if anyone wants to see) So I took the engine out, had the block...
  4. J
    FOX. ICON, or KINGS 4 inch suspension lift
    Which of these lifts are best for my 2018 ram 1500 big horn 4x4 for a 4 inch suspension lift I want to run 35’s but I’m trying to figure which lift is better as a daily driver, light off roading and medium at most. best in the long run, as well will put all of the angles in the best spots?
  5. W
    Rough and Inconsistent Idle, frequent stalling and bogging down under acceleration
    I have a 2005 Dodge Ram 1500 Hemi that I have been trying to fix for almost two years now. My brother ran it to empty one too many times and clogged up Injectors and the truck wouldn't start properly again. Had my mechanic take it apart to find the cause and found that a valve had broken off...
