2020 5.7 etorque coil boot
mrrogers951
Coming up on 90000 miles and getting ngk plugs but would like to replace coil pack boots also. Anybody know a part # as all online show up to 2016.
Should be the same coil boot and spring.The only differance is the spring inside the boot,later trucks utilize a resistor under the spring and consequently have a shorter spring,alot of the replacement coil boots have the longer spring,so you can eliminate the resistor.
You could also pull your injectors and do a home clean on them pretty easily.
