Hi all,
I have a 2011 1500 Outdoorsman 4x4 with 5.7L Hemi and 5-speed trans. The rear differential has a 3.92 gear ratio and is the anti-spin type.
Getting ready to replace the fluid and cover gasket, but I see conflicting info on what weight of gear oil to use. Manual states 75w-90 in both...
I’m changing rear differential gasket and oil. used vehicle did not come with manual and I’m not sure whether this truck has limited slip differential. I’ve watched video & trying out some method, such as jacking up with two stands while rotating tires.
I’d like to make sure the truck (2006...
