drag link
  1. 6
    Front end suspension
    Hello, i have a 2017 ram 3500 with 6 inch bds lift and dual bds steering stabilizer. Question is if i want a beefier tie rod setup lets say kryptonite or synergy will bds dual steering stabilizer clamp on? Also thinking of upgrading drag link aswell and adding adjustable track bar. Which...
  2. R
    V06 recall frustration
    I just brought my 2017 Ram 2500 Laramie, which I bought new, in for new fuel filters and an alignment. I was informed that due to the V06 recall fix I had done in 2019, which was to weld a nut on the drag link, they were unable to perform the alignment. Apparently once welded, adjustments...
  3. RamShark1
    2015 2500HD 4x4 alignment, recall issue, Help
    Hello Everyone- I need some input on my 2015 2500 4x4 currently in the body shop with a front alignment issue probably from a hit and run front left swipe. My right front tire started wearing fast. I though maybe it was just one of my aggressive driving moves and blew it off, unfortunately I...
  4. 18MegaRam
    Drag Link Reimbursement?
    Has anyone been reimbursed when replacing the drag link with an after-market Synergy drag link as related to the drag link recall? I've seen a lot of talk about the "weld" repair, but nothing about reimbursement for a real fix.
  5. R
    Drag Link V06 Recall
    So normally I dont like to complain about stuff but certain situations require it. Before this recall came out I noticed my steering wheel was off center so I immediately checked the drag link. Low and behold you could have turned those two nuts with your hands that's how loose they were from...
