engine replacement
  1. I
    Dealer recommends engine replacement for @63k miles
    Had the hemi tick the past month. Had a misfire code on one of the cylinders. They said one of the rods are likely bent. Dealership recommends a cam and lifter replacement for 10k or engine replacement for 14k on my 2015 ram v8 with 63000 miles on it. Might just pay the diagnostic and take to...
  2. B
    2012 5.7 Engine Failure
    Howdy, y'all. A year into owning my 2012 1500, 5.7 Hemi and the engine crapped out. I'm suspecting it's cam and lifter failure. Cylinder 3 misfire after replacing all spark plugs. Technician found gunk (oil and carbon I suspect) built up on one side of cylinder 3 and a 120 psi pressure. He got...
  3. N
    Engine replacement for 1999 Dodge Ram 1500, 5.9l Magnum
    Bought my first Dodge truck about 6 months ago. A 1999 1500, with a 5.9l Magnum engine. The engine is nearing or over the 300,000 km mark (not sure as the odometer works only occasionally, due to what i assume is a transmission speed sensor, given that the speedometer also works only...
