exhaust conversion
  1. JCarr98Ram
    H-pipe possible?
    Hello, I am curious if an H-pipe exhaust is possible on a 1998 dodge ram 1500(5.9L)? I am currently looking to make my single y-pipe exhaust into a duel exhaust. If anyone can give me advice on if you were able to make this happen or what modifications you had to make in order to make an H-pipe...
  2. S
    Need some advice / help. JBA headers
    Currently installing JBA ceramic shortys on my 2014 5.7 4x4. Passenger side is done dust need to re torque after a few heat cycles. Drivers side I’m having issues. 1. Best tool or way to tighten the 2 most bottom rear next to the starter header bolts. Using ARP 10 mill heads. I’ve used a...
  3. S
    2020 Ram 1500 Header/exhaust recommendations
    My truck: 2020 Ram 1500 Laramie Longhorn 5.7L V8 Etorque Motor. so I know it is common for the manifolds bolts to break or the manifold itself to crack. so knowing this I am looking for a non cast iron option that doesn't need need to be tuned when done. I have looked and found this header but...
  4. 440AirForce
    2021 5.7L Bighorn Quad Cab, Needs a Rumble
    I just bought a 2021 5.7L Bighorn Quad cab, but it’s too quiet. I need to wake the neighbors with a morning rumble, any suggestions for exhaust upgrade? I’m thinking of straight through pipes, no drone. I’ve looked at the other posts , but nigh specifically for a 2021. Thanks
  5. Donyell
    Hmm
    Should I put a flow master super 10 and axle dump with a 5inch outlet tip
  6. S
    1997 Ram Conversion to Dual Exhaust
    Hello all. First post for me so go easy! I have a 1997 Ram 1500, 5.9L Magnum, auto trans, 4wd, with 89K original miles . I just removed the 6.5' bed to straighten the front panel and then I will be pressure washer sandblasting the bed to remove the rust, followed by primer and paint. In the...
