fuel delivery
  1. S
    Mystery part in fuel tank
    Hey guys I’ve been having some fuel pump issues on my 2012 ram 2500 5.7 hemi (ran a fuel pressure test and had about 10 psi and very quick bleed back) and dropped my tank and pulled my pump and when I pulled the pump I found this part at the bottom of the tank, compared to the new pump, doesn’t...
  2. Ellis32198
    Ongoing Fuel Issue Leads to Stalling
    Hi all. Haven't posted here in a minute and I must apologize up front, it's long and a doozy. I'm hoping I can get some direction toward a resolution for this issue as several mechanics, along with myself, have not been able to troubleshoot and correct the problem. So here goes and thanks in...
  3. A
    Fuel Pressure Test HOW???
    So I have a 2012 Dodge Ram 2500 5.7. Last 3 days I’ve turned on the truck to just get a sputter start and then turn off, it sounds and feels like the truck needs fuel. I have a full tank, I also did the test to turn the key to the on position for 5 seconds and wait and then turn it on, it works...
  4. rrb6699
    The RPMs drop low then return When decelerating driving without pedal
    This is not a problem at this time but I feel it could be a problem. Truck idles fine sitting still or in park and when I give it gas it seems to accelerate fine, however, when I let off the gas doing any speed at all even 20 miles per hour, RPMs and idle drop very low while I'm coasting then...
