fuel system
  1. A
    Can you identify the original factory cold weather package and fuel system? 2nd gen diesel.
    I have a 1997 Dodge Diesel 2500 and I'd like to keep it original. The fuel heater died in mine and I'd like some help identifying what cold weather package my truck has. It looks factory original. Does anyone have photos of their factory original fuel system upgrade and cold weather package...
  2. 1
    Fuel Vent Hose Size?
    Hello. I’ve got a 1998 Ram 1500 5.2L. My gas vent hose (the smaller line coming off the filler neck) has a hole in it. Would anyone happen to know the size of this hose, like the inside diameter?
  3. Rob McClure
    ignition coil pack question
    Hi all ! so im thinking of putting in new ignition coil packs in my truck ( 2015 ram 1500 5.7lt v8 SLT) can someone recommend some quality coils ? i was looking at these on amazon https://www.amazon.com/gp/product/B082K64HZ6/ref=crt_ewc_title_srh_1?ie=UTF8&psc=1&smid=AAUEGXSSJIQEC also im...
  4. S
    Fuel System Failure
    Hey y’all - have a 2021 with what appears to be a fuel system failure. Truck was manufactured in Dec 2020 and I’m suspicious about it having the recalled pump on the 2019-2020 model years. A fuel sampling from the tank showed no contaminated but a second sample found trace amounts of DEF but I...
  5. Sligh
    Collapsed fuel tank
    I have a stock 2008 Ram 3500 6.7 cab and chassis. Had P0087 several months back. Replaced the fuel filter, cleared the code, and have not had an issue. Last week, lost all power, coasted to a stop. I saw only P0087. Towed it to a local ship. They took a look and said that the fuel tank...
  6. W
    busted fuel line.
    My father has a 2001 ram 2500 with a gas 5.9L. the fuel line connecting the rails on top of the engine decided to turn into a geyser. does anyone know what size line it is and how to remove it. doesn't look like there is any sort of clamp holding it in place and i don't want to just rip it out...
  7. C
    Black Fuel Filter at Engine
    I thought I kept getting Bad Fuel. I changed front and rear Fuel filters 3 different times over 4 or 5 tanks of Fuel. Each time the Truck would barely Run. When I pulled the Engine Fuel Filter it is Black kinda the color of used Engine oil. Could this be a Oil Cooler going out or still got...
  8. Keith_3500_59
    STP for gas in my Cummins Diesel 5.9L
    Hey, I accidently put STP Gas treatement in my Dodge Ram 3500 5.9L Cummins Diesel. Will that cause damage to my fuel system?
