headlight assembly
  1. I
    Front Headlight Replacement Help/Contact at Ram 5th Generation
    Good day, first time poster. Hoping for some help and sorry for the long post. 1. I realize I don't have much of leg to stand on. 2. I have really liked by truck, but very frustrated. 3. I am not by any stretch of the imagination a "gearhead". I own a 2019 Ram 1500 Laramie Longhorn 5.7 (61k...
  2. M
    2014 Tradesman - Need help with Quad Style Oem Passenger light assembly replacement.
    New to the forums here but not new to how these work! I did search past thread to see if I could get my answer before posting. I was not able to find an answer. 2014 ram 1500 3.6l Quad Tradesmen with the basic quad headlights h11/9005 I must have caught a rock because my passenger assembly is...
  3. D
    Headlight problem
    So my wife and kids got me some new headlights for my 2014 2500 Laramie longhorn. The lights that they bought me are Dodge Ram 1500 2500 3500 Black LED Bar Plank style Headlights pair part number is cs306-b10pa-7v The problem is I already have factory projection headlights. The connection...
  4. T
    2015 Ram Sport Headlight Replacement
    I am looking to replace my headlight assemblies but I am unable to find something close to what I have now. I have a 2015 black sport with projector headlights. What I am looking for: 1. Halogen projector headlight. 2. LED turn signal. 3. Black interior. I have found plenty of halogens...
  5. I
    Aftermarket Headlights
    I have a set of aftermarket projector DRL headlights that are “plug and play” that come with a resistor and are supposed to plug straight in and work. Well here is the deal. I have plugged them up and the driver side light works and the passenger side doesn’t. They both work until I give the...
  6. Visionari
    Dual Beam Headlight Replacement
    Who here has a 2009-2012 and has replaced their headlights? Looking for good LED or Projector headlights that are compatible with the connectors on the dual beam headlights. I wanted to go OEM projectors, but I can't find the harness for these anymore that are dual beam compatible. Anyone...
  7. R
    Morimoto XB Gen 2 Fitment issue
    So I've recently installed the Morimoto XB Headlights on my Ram 1500, and for some reason I cannot get the passenger side headlight to "pop" in place. Does anyone else has this issue. Note: I can't exchange them since I bought them open-box.
  8. H
    Projector internal wiring!
    Hey! My 2015 with OEM projectors has an issue with the passenger side low beam not working. I have diagnosed to the wiring inside the housing - no power to the bulb, no continuity from bulb connector to external housing connector, 12V present at the female main connector from truck to headlamp...
  9. Oilfieldman
    Led headlight upgrade for 2018 2500 tradesman
    So as everybody knows the factory quad headlights are pathetic. I did a lot of research trying to find a headlight upgrade that didn’t require putting in projectors. Headlightexperts.com had exactly what I needed. It was around $100 for low beam and $100 for high beam. They claimed that the beam...
  10. G
    Who made these headlights?
    I was at a wholesaler and picked these used headlights up for $20, cuz I wanted something black for my black 2012 1500 Laramie. I figured I could always resell them if they don’t work. I’m trying to figure out if they’re worth going through the hassle of installing. I don’t see any manufacturer...
  11. Jokybrto
    ***2011 RAM 1500 Truck Build With a Bunch of new Goodies***
    Good morning, I'm new to the Forum. I inherited my Dads 1500 RAM 3 years ago after he passed away. My Dad and I talked about upgrading to the dual exhaust and bumper on his Standard cab (We never got around to it before he passed). Not making this into a sad story, but a happy one... I decided...
  12. F
    Headlight Housing Upgrade Options
    I got into a fender bender and destroyed the headlight on the driver side of my '16 RAM 1500 Tradesman. I'm trying to figure out if I should upgrade the housing, as long as I have to buy a new one, and if so, what my options are. I don't want to spend a ton, so maybe just a mild upgrade? I'm...
  13. OEDRO
    Dodge Ram Chrome Housing Amber Headlight Assembly
    OEDRO® 2002-2005 Dodge Ram 1500 Headlights,2003-2005 Dodge Ram 2500/3500 Headlamps/Light Pick up Truck 2-Dr&4-Dr Chrome Housing Amber Side Clear Lens Left+Right Waterproof High quality material High light transmission mask Vehicle Fitment-2002 2003 2004 2005 Dodge Ram 1500 healight I...
  14. OEDRO
    Buy Headlight With Promo Code For 2006-2008 Ram 1500, 2006-2009 Ram 2500 3500
    10% OFF ☆ PROMO CODE: HEADLIGHTS10 OEDRO® Housing Amber Reflector Left+Right Headlights for 2006-2008 Dodge Ram 1500 2006-2009 Dodge Ram 2500 3500 Shop Now! Fitment - 2002-2005 Dodge Ram 1500 Headlights,2003-2005 Dodge Ram 2500/3500 Features: - EXCELLENT VALUE &DURABLE MATERIALS - EASY...
  15. 1ATony
    New headlights just for your Ram
    New headlights just for your Ram Need to replace your Ram’s broken, faded or old headlight assembly? Shop our brand new, direct-fit options now: http://1aau.to/m/headlights-7
