ItsOstn
West Virginia
5.7L V8 Hemi
I have a set of aftermarket projector DRL headlights that are “plug and play” that come with a resistor and are supposed to plug straight in and work. Well here is the deal. I have plugged them up and the driver side light works and the passenger side doesn’t. They both work until I give the truck gas and then the passenger side flickers off and don’t come back on until I turn the truck off and restart it. I’ve done Alfa OBD, I’ve switched the headlights to see if it’s the headlights. The driver side stays on but when I switch it to the passenger side same result. But with my stocks in everything works. Should I strip out the resistor? What are some ideas?
