Dual Beam Headlight Replacement
Visionari
Rockford, IL
Who here has a 2009-2012 and has replaced their headlights?
Looking for good LED or Projector headlights that are compatible with the connectors on the dual beam headlights.
I wanted to go OEM projectors, but I can't find the harness for these anymore that are dual beam compatible.
Anyone have a good link to a harness for the OEM Projectors that is compatible with the dual beam lights?
I know I am gonna need AlfaOBD to fix the low beams shutting off with the high beams, I'm just look for good suggestions on what is compatible with the wiring for the Dual Beam Headlights.
Picture attached of thr headlight style being discussed, as to not be confused with the newer style, quad headlights.
Thank you!
The connection to those headlights are the same as what plugs into the Quad headlights(Quads have separate High and Low beam bulbs).
If you change to a Quad headlight, you'll want to use AlfaOBD to change the headlight type in the BCM to Quad so the Lows stay on with the High beams.
Lots of members on this forum have ran Apharex headlights on their trucks: https://alpharexusa.com/product-category/performance-lighting/ram-truck-2009-2018/
If you decide to go with the OEM projectors, you'll need this adapter: https://retroshop.us/products/4th-gen-projector-adapter-v3-1-pair
Visionari
Visionari
Rockford, IL
Thank you! I wasn't sure because it says it's only for 2013-2018. Good information!
You can also search Modifystreet Ram headlights on Amazon (or the web) for OEM looking projector style headlights. They're actually made by Apharex.
Probably the only reason a 4Gen ram replacement headlight would state for 13-18 only trucks is because the duals headlights, that can be changed with AlfaOBD.
Visionari
Visionari
Rockford, IL
I ordered a set today from alpharex! Can't wait for them to come in, and I'll be using AlfaOBD to fix the high beam issue
Carbary
