New here. Been having issues with my Ram after gassing up. It idles and chocked after I gas up. Been thinking it might be the fuel pump but wanted a second opinion before I pull the trigger. Cleaned the throttle body, switched EVAP Purge Valve, and
ESIM / NVLD Leak Detection Switch since i...
Hi guys, new to posts and ram 5.7 truck in General. But basically my issue is the multiple misfire code I am getting, and it does not show me which cylinder is actually misfiring. I had got the truck for a fair price due to misfire on cylinder #5 and did all the basic tests and ended up needing...
Hey y’all.. I’m having some major electrical issues with my 2012 ram 1500. Is it possible to modify my truck to run with a carb and an electric fuel pump etc?
2013 1500 Sport 4wd 5.7 push button start
This past weekend I replaced the front calipers, rotor and pads due to a caliper locking up. I say this not knowing if it could be related.
I have been driving all week with no problem and drove about 30 min today then parked on a slight grade in a...
About a week ago I was working out in death valley. From death valley to my house is around 5 hours. My truck ran perfectly throughout the whole drive. We even stopped a couple times and I shut it off and it would turn back on no problem.
When I reached my house I shut off the truck and went...
hey guys,
Ya got a newbie here.
My 2013 Ram 2500 6.7 sometimes won't start.
About a 2 weeks ago I put the key in the ignition and it sounded like it did a 1/8 crank then stopped. I disconnected the battery to reset but no luck. Then grabbed the battery charger and she turned right on. I then...
