rear diff
  1. B
    Rear pinion seal replacement/ socket sizes
    The rear pinion seal is not difficult, although I had a hard time finding the pinion bolt socket size before getting into the project. So here is what I had. Drive shaft bolts are 15mm Pinion bolt is 1 1/4” I have a 2011, 1500 sport that had the rear end recall. I wasn’t expecting to run into...
  2. Rob McClure
    Rear diff fluid Picture
    HI guys I just bought my fluid for the rear diff , I also bought the friction modifier , am I good to go ?
  3. Rod Knock
    Castrol Syntrax 75W-90 Long Life and 75W-140 Limited Slip - Anyone using it?
    I have to do my driveline service and I was looking at different gear oils. I know that Redline Gear Lube is popular, and I have no doubt that it's very good. Alternatevely I am also partial to Castrol products, and looking at the spec sheets and manufacturer approvals that their European...
  4. R
    Rear end whine....
    I have a 2012 1500 4x4 Laramie. 125,000 on it. For about a month I have a even pitched whine from the back. Thought it may be a wheel bearing and changed out both. Still there. It starts at 30 and peaks at 45mph. Goes away at about 55mph. Seems to be most pronounced slowing to a stop...
  5. S
    Rear diff problem need help
    Popped cover off as truck was clanking on slow turns and tires dragging. Metal dust in fluid and about 8 good chunks of metal. Clutch pack on driver side looks broken. Can I pull the ring and diff assembly by popping axle clips slide them out a bit to pull assembly? Rebuild or replace with new...
Austinv
